Kingbull has expanded its e-bike portfolio with the launch of two next-generation e-bikes, the Verve and the Jumper Go. Both e-bikes, designed to be used for both commuters and off-road explorers, share very similar specifications, albeit with a few tweaks in terms of design and top speed range. More specifically, the Verve has a foldable design, while the Jumper Go comes with a non-foldable design.
The Verve and the Jumper Go boast a similar 750 W Bafang brushless geared-hub motor with 80 Nm torque, which delivers up to 20 & 28 mph (~32.1 & 48 kph) top speed and helps to tackle inclines up to 35°. A massive Samsung 960 Wh removable lithium battery is fitted in both e-bikes, enabling you to ride for up to 80 miles (128 km) on a single charge.
At the core of the Verve and Jumper Go is a sturdy and durable aluminum step-through frame, which is complemented by TEKTRO HD-E3940 4-piston hydraulic brakes with 180 mm discs and torque and brake sensors. Equipped with an 8-speed Shimano drivetrain, both e-bikes feature 20” x 4.0” Kenda tires and a Zoom front suspension with 80 mm travel, offering commuters a smooth and comfortable ride on bumpy roads and rugged terrain.
Furthermore, Kingbull has incorporated a dynamic LED display on the handlebar, which showcases real-time metrics such as battery percentage, max speed, distance, and more. Additionally, there are integrated 48V headlights on both vehicles that offer better visibility during nighttime. The all-aluminum frame and rear rack can handle payloads of up to 450 lbs (204 kg).
Speaking of the weight, the Verve weighs around 77 lbs (34.9 kg), while the Jumper Go is slightly heavier than the former, weighing 81 lbs (36.7 kg).
Available in white and black colorways, the Verve and the Jumper Go are priced at $1,999 and $2,499, respectively. Additionally, as part of the launch offer, Kingbull is offering both e-bikes at a special launch price of $1,799 and $1,899. Both e-bikes are currently available for pre-order via Kingbull's official website, with shipping starting on May 15.
Notebookcheck
