Honda SP160 (2023) Launched at ₹1.17 Lakh
FireShot Capture 268 - Honda Motorcycle & Scooter India launches new bike SP160 at Rs 1.17 l_ ...png
The Honda Unicorn is a very successful motorcycle in the brand’s 150-160cc segment. So much so that the motorcycle was reintroduced owing to its popular demand in the premium commuter market. Now, using the Unicorn’s platform which is known for its practicality and efficiency, Honda has introduced a sportier version of the motorcycle, christened the SP160.
The motorcycle has been launched at a starting price of Rs 1.17 lakh (ex-showroom, Delhi) and will be offered in two variants, a twin-disc and a disc-drum option. Honda is offering the SP160 with six colour options that includes Matte Dark Blue Metallic, Pearl Spartan Red, Matte Axis Gray Metallic, Pearl Ignite Black, Matte Marvel Blue Metallic and Pearl Deep Ground Gray.
The SP160 draws its styling cues from its smaller sibling, the SP125. It features an LED headlamp with a smoked windscreen and a bikini fairing with sharp lines. The edgy contours continue towards the rest of the bike with prominent tank extensions with faux air vents. Graphics and an engine cowl add to the sportiness and modern appeal. The bike features a 12-litre fuel tank, while the tail section features a one-piece grab handle and a signature H-shaped LED tail lamp. The SP160 gets an all-digital instrument console that packs a tachometer, speedometer, two trip meters, odometer, gear position indicator, average fuel consumption, average speed, and some more. You also get a hazard switch that’s located on the right switchgear, apart from an engine kill switch.
Coming to the powertrain, Honda has opted for the tried, tested and trusted motor from the Unicorn. It is the same 162.71 cc single-pot air-cooled fuel-injected mill that is rated to produce 13.27 bhp of max power at 7,500 rpm and 14.58 Nm of peak torque at 5,500 rpm, mated to the same 5-speed gearbox. To stay up-to-date with the latest emission norms and regulations, the motor is OBD-II and E20 fuel compliant.
The SP160 uses the same diamond-type frame pivoted to a box-type swingarm from the unicorn. The motorcycle is suspended by a telescopic fork setup at the front and a monoshock at the rear. For braking, the top-spec variant comes with disc brakes at both ends while the lower variant comes with a disc-drum setup. The system is accompanied by single-channel ABS. Unlike the Unicorn, which rides on 18-inch wheels, the SP160 rides on 17-inch wheels shod with MRF Nylogrip Zapper tyres.
The saddle height on the SP160 measures 796 mm while the ground clearance is set at 177 mm. In terms of kerb weight, the SP160 tips the scale at 139 kg for the single-disc variant and 141 kg for the double-disc variant.
With deliveries likely to begin by the end of the month, the SP160 locks horns with the Bajaj Pulsar P150, TVS Apache RTR 160 2V and the Yamaha FZS V4.
Car&bike
Honda SP160 updated, priced from Rs 1.22 lakh
Another day closer to 2025, another Honda commuter updated. As with the Activa 125 and SP125 that have been updated in the past few days, the SP160 has now followed suit, gaining the new 4.2-inch TFT display, a USB-C charging port and OBD-2B compliance. With this update, prices have gone up by Rs 3,000 - Rs 5,000, depending on the variant.
The Honda SP160 is the bigger sibling to the SP125 but its fundamentals are largely shared with the popular Unicorn. This update brings the SP160 in line with the latest OBD-2B emission standards, which come into effect next year. Honda has also given the SP160 a 4.2-inch TFT display that has Bluetooth connectivity, making it the only commuter in the class to do so. Another useful addition is the USB-C charging port.
Aside from these changes, the SP160 remains the same as it's always been with the 162.71cc, single-cylinder engine now rated for 13.2hp and 14.8Nm of torque. These figures are a small departure from the earlier SP160 which used to make 13.5hp and 14.58Nm.
Available in four colours, the updated Honda SP160 is priced at Rs 1,21,951 (single disc) and Rs 1,27,956 (double disc), which is an increase of Rs 3,000 for the former and Rs 4,605 for the latter.
All prices ex-showroom, Delhi
Autocar
