Before I pose my question I would like to give a little background on the issue.
I find the brakes in my new Swift Vxi a bit indifferent. Basically, when I was driving my old Wagon R, you are driving down the road and see a traffic jam / signal about 100-150 meters away. I don't prescribe to going and braking just behind the car in front. Rather, I brake with little pressure in well in advance, then unload and roll to the traffic and apply braking just at the end where very little braking is required. Or I apply brakes with a little pressure from well in advance so the car slows down and brakes all the way to the stop. In both cases, I have much more distance to control my speed, so its safer.
However, the Swift is different. If you place a little pressure on the brake pedal, nothing happens. By then you are already close to the car in front, so you have to press the pedal harder leading to a jerk at the end when the car stops. I noticed the pedal goes in first before the braking action starts decelerating the car, something that didn't happen in my old Wagon R. What am I missing?
Note that final deceleration is quite strong, its just the initial braking effect that is not there, meaning I cant drive the car as smoothly as I could the Wagon R.
When I received the car, the showroom technician pointed out that the brake oil is white (clear) for now. That's a weird thing to point out. Is the soft braking related to this? Do cars come with a different brake fluid when new and do they replace in service or something? The manual does say not to hard brake in the first 300km or something like that. My 1st service is due next week
Also, I am currently running stock brake pads. Not sure what make they are. Should I get them replaced with Brembo or something?
Also, I had considered retrofitting alloys for better brake cooling only (and no other purpose). I postponed allow wheel purchase to the 6 month service or later because I was told that it doesn't really matter. Should I go for alloys now?
Ameyam
Ameyam
