Audi RS Q8 comes with a shiny black singleframe grille with a black logo around the car, RS HD Matrix LED headlights and LED taillights are all black. Added with a custom set of wheels, the size is 22 - 23 inches, the largest that Audi has ever put in order to receive a black or red brake caliper. With brake discs measuring 420 mm in the front and 370 mm in the back
The room is spacious, as is the big brother SUV, adding sportiness with the use of Alcantara and all-around carbon material. With air conditioning and massage Red-threaded gear shift knob and steering wheel, Audi virtual cockpit system and MMI screen re-adjusted to show driving-related values. The maximum luggage space is 1,755 liters. When the rear seat is folded down
4.0-liter twin-turbo V8 diesel engine with 600 PS of maximum power of 800 Nm of torque at 2,200 - 4,500 rpm. The 48-volt Mild Hybrid system is paired with an 8-speed automatic transmission. 4 variable quattro wheels, power transmission between front and rear dual wheels
The front-rear suspension is a five-link, adjustable height, up to 90 mm. Steering system is a 4-wheel system by turning the rear wheel in different directions from the front wheel up to 5 degrees when using low speed. And facing the same direction for up to 1.5 degrees at high speed
8 different driving styles via the Audi Drive Select system include comfort, auto, dynamic, efficiency, allroad, offroad, RS1 and RS2, which will affect the response of various systems. The engine, transmission, steering wheel, suspension, 4 wheel steering, the sound of the engine And automatic air conditioning systems
Read:
