Ather 450X Gen-3 Launched in India
Ather Energy has launched the Gen 3 450X and 450 Plus electric scooters at Rs 1.39 lakh and Rs 1.17 lakh, respectively (ex-showroom, Delhi). The 450X is Rs 1,000 more expensive than before in Delhi, while across India, the average increase is around Rs 5,000. But the price hike will vary from city to city.
The major change on the Ather 450X and 450 Plus is the inclusion of a larger 3.7kWh up from the outgoing version’s 2.9kWh unit. This results in the 450X’s ARAI-certified range going up to 146km from 116km of the previous model, with the real world range going up to 105km (Eco mode) from 85km. For the 450 Plus, ARAI range is up to 108km from 100km, while the real world range is up to 85km (Eco mode) from 70km. The larger battery pack has also resulted in the kerb weight going up slightly for both scooters, from 108kg to 111.6kg.
Ather has also uprated the electric motor’s maximum output on the 450X to 6.2kW (Warp mode). The 450 Plus continues to be rated at 5.4kW peak, and continuous output and torque figures for both versions remain the same, at 3.3kW and 26Nm (450X), 22Nm (450 Plus).
For better grip in all weather conditions and a shorter braking distance, the company has given both scooters wider 100/80-12 rear tyres, up from the 90/90-12 of the outgoing versions. Ather has also upgraded the RAM of the dashboard to a 2GB unit, up from 1GB of the previous versions.
