Aston Martin has revealed the next successor in its 25-year bloodline with a new V12-engine, which returns 835 PS and 1000 Nm. This new V12 engine will soon make its first appearance in the new Aston Martin Vanquish.
- The result of a complete re-design, targeting optimisation and improvement, the new engine refines every stage of the internal combustion process.
- Hardware highlights of the new V12 engine include a strengthened cylinder block and conrods, redesigned cylinder heads incorporating reprofiled camshafts, plus new intake and exhaust ports.
- The repositioned spark plugs and new higher flowrate fuel injectors deliver optimised combustion. Additionally, new higher speed, reduced inertia turbochargers increase performance and throttle response.
- The new V12 engine, which will feature across Aston Martin's most exclusive and limited availability models, will be handcrafted, year by year, in strictly limited numbers.
- The engine will make its first appearance in the new Aston Martin Vanquish later in 2024 when further technical details will be revealed.
