Timing Belt and Tensioner replacement in Figo.
A little bit of background:
During this Holi festival (25th march 2024), I got a window to work on my Figo. Timing belt replacement was looong pending, and it was eating me up from inside, because you see, the Ford Duratec 1.2 litre is an Interference engine. This means that if the belt snaps on a running engine, then Kaboom !!. Valves will bend and piston damages/scoring might happen. And if the engine is already running at a high RPM and speed like on an open highway or such then one can imagine the damages that will occur. Basically I will loose the engine !!
And I have changed pretty much every rubber part and age related degeneration part and every fluid on this car except the damn Timing belt, which if you see from my point of view , is the most important part and should be changed first. And all this was causing me tension.
Tension because I wanted to get this done, but I did not want to go to the Ford ASS for this. I wanted to do it all by myself DIY way . And herein lies the whole problem! It's a big job. Doing it as a DIY will need space.I have 7 feet wide parking space,which is not much considering that the car itself occupies most of it, so doors cannot be opened properly.You have to move around the car for jacking on both wheels,so yes,it was an issue. Moreover I needed tools.and lots of them. And tools specific to my car, not just generic spanners and sockets. also I needed an assistant,which I did not have.Its a 2 man job at the Ford ASS.
And even after all this, if I succeeded in opening the required engine components, and still screwed up the already perfectly timed engine, I will look like the biggest fool on the planet, at least in my eyes! So it has to be done right the first time or don't do it at all ! But I was stubborn.I informed my trusted mechanic at Ford and asked if I can do it at my home.His reply dampened my spirits furthur. "Sir, Nobody in his right minds will think of doing it as a DIY at home, let alone attempt it. It's not possible sir, and ultimately you will be towing your car to us so what's the point."
Well towing the car to the Ford ASS with its engine opened by an oversmart owner will be a laughing point at the ASS. And it would be very insulting to me.So that was also causing tension.
