This thread is specially dedicated for small car owners, (800,alto,zen,omni,etc)
When people install ICE, and other electrical accessories have you thought of the the charging capacity of the alternator\ battery.
Here comes my issue, I have an 100\90 head lamp wiring kit, 55 watt fog lamps. (now planning to get an amp\sub)
When ever I use both my horn doesn't work, other lights get dim, at night times in signals if I turn off my engine, then I am gone, it wont crank as the battery would not have been charged.
Not only me many others are facing same problems.![Frustration [frustration] [frustration]](https://www.theautomotiveindia.com/forums/images/smilies/Frustration.gif)
My questions-
-Can we upgrade the alternator (which produces more amps),
-Will it fit to same position\ alteration required ?
-Will the ECU have some issues if thr is more power is produced ?
800's alternator charges upto 35 amps.
Zen\alto -40 - 45 amps
Esteem - 50 amps
Swift - 65-70 amps.
Now my plan is get get an esteem's or swifts alternator, but I am thinking about the battery and the wiring. (ECU)
Pls Help ..![Smile [:)] [:)]](https://www.theautomotiveindia.com/forums/images/smilies/Smile.gif)
My questions-
Esteem - 50 amps
Swift - 65-70 amps.
Pls Help ..
