Hello Friends,
Today we will be reviewing a Simple, Budget Subwoofer that goes by the name of JBL CS1215 or CS1215B. I was looking for a Pocket friendly, Sealed Woofer for my car and home use. I found this JBL woofer for quite a bargain at around INR 4k. The Woofer came with Factory designed Sealed box which is quite good. I hunted the Net about for a week but could't find any decent reviews for this product, so here I am posting my own review to help others decide.
The Spec-
Type 12 inch (300 mm) Subwoofer
Series CS
Peak power 1100 W
RMS power 275 W
Sensitivity 90 dB
Frequency response 35Hz-200Hz
Impedance 4 ohm
Voice Coil Diameter 50 mm
Mounting Depth 153 mm
The Build-
The Subwoofer Comes with a Sealed Box. I always prefer sealed boxes as they deliver tighter, More accurate Box. The Box design is Sturdy and is Covered in Black Carpet. There are 2 Steel bars to protect the subwoofer cone. The Look is very classy although I sometimes feel worried that Bags/Luggage Placed in Car could damage the Woofer cone. A full Grille would be welcome here.
The woofer box is deeper than I would like and hence eats up the last row seats which could be a problem for some of you.
Connection-
The Screw type Quick disconnect Connections are Located at the Back of woofer. Being a Single voice coil, Connections are as simple at it gets.
Woofer Quality-
Being a budget woofer, I won't be very critical about the Quality. The Woofer cone is made of Fiber. The surround Is made of Rubber. The Excursion capablity is Medium. This is not a woofer that could blow your ears off. Rather, its a simple product to augment the low end of your system. Its the perefct woofer to causual listeners who love deep, accurate Bass. SPL and volume lovers should look elsewhere.
However, In comparision to my SONY GTX 150LE 15 inch sealed monster sub, the difference is quality is noticeable. The Sony 15 inch has better quality, High roll surround, Stiffer cone, and overall Better build quality than this one. Obiviously It costs over double this JB CS1215 woofer. However, for the price, The build quality leaves nothing to fret about.
Woofer Performance-
The Performance is satisfactory. I have connected it to my JBL GTX 646 4 channel amp. The AMP is wired in Bridged Mode and Pushes in the likes of 200W RMS to the Sub. The Volume is good enough for my needs and the Thump is decent. The woofer has adequate output in Low end spectrum like 35~50Hz.
I Have also tested the JBL CS1215 on my home Amp and performance is still very good. My home amp is rated just at 24W RMS and the higher sensitivity and Lighter cone of the woofer helps gain decent bass at Low RMS. I would highly suggest people go for this woofer for their home audio compared to puny 5 inch and 6.5 inch woofers you usually get with Home Theater systems or 5.1 Systems. At the Same RMS and volume, this SUB is Insanely better in Sound quality and volume.
I love the TONE of woofer which has low,growling and deep bass rather than the DOOF DOOF shallow bass that some people like. If you want DOOF DOOF or Boomy bass, please look for a ported woofer.
Price-
The Woofer was brought for INR 4k from Bombay.
Links-
JBL - CS1215B - 12 inch Subwoofer Box Enclosure (1100 W) - Buy Online @ Snapdeal.com
http://www.theautomotiveindia.com/f...oo-detailed-review-decals-audio-led-mods.html
The Spec-
Series CS
Peak power 1100 W
RMS power 275 W
Sensitivity 90 dB
Impedance 4 ohm
The Build-
Connection-
Woofer Quality-
Woofer Performance-
Price-
Links-
