300 kms review:
now, i wont call this a review, but here are some things i noticed in the first 300 kms with my car:
+ tyre pressure sensor is good, accurate with only a negligible error.
+ reverse sensors work well, shows even the direction of obstacle and detects even the corners of the bumper.
+ cruise control is working fine, no issues there.
+ engine is very very refined, its all go and no show! amazing acceleration with zero vibrations.
+ features like theatre style illumination & headlights which stay on for 30 seconds after you remote lock the car add to the "feel good" factor of the car.
+ the voice assist system reminds you of everything from low fuel to seat belt, door open, low brake fluid, handbrake engaged and what not!
+ the lights on the footpegs are nice and do help.
+ driver's window has auto up/down feature with anti-pinch which goes down automatically as it senses an obstacle. nice.
+ automatic headlights are working fine, but does get switched on if the car is parked in a shed even in daytime.
- there is some vibration from the gear lever in the 3rd gear. have to get it checked in its 1st service.
- there is a strange sound like "whoa" from the car. it is not sounding like a defect or rattle. its like the car is purposely making that noise as a reminder or caution, but we cant figure out what it is!
- the ride though good, should have been better.
- small shortcomings which i already knew like absence of cruise control indication and electric side view mirrors.
- automatic wipers work fine but does not stop as soon as the glass is dry. this is mentioned even in the manual as the sensor senses even little drops on the windshield.
850 kms review:* because of the rains in mumbai, i could check my car's automatic wipers. they are working perfect, quite contrary to what i read in some reviews. switches on/off automatically and increases/decreases speed according to the intensity of rain. the only grouse is a mild clicking sound can be heard from the sensors's receiver located under the front seat. i dont know whether its normal, anyways have to get it checked in the first service.
* the strange noise like "whoa" which i mentioned earlier is still present. now we are sure that its not a defect as we have heard it even when the car is not moving but we have no idea what it is trying to convey!
* if the scorpio is remote locked, then it should be unlocked only with the remote as the engine immobiliser get activated. any attempt to open it with a key will trigger the alarm and the engine wont start. if your remote battery is dead, then you can open the car with a key. to stop the alarm, there is a button in the glovebox. turn on the ignition, press this button and turn off the ignition. repeat this procedure five times. this is the way to enter your password. your default password is "11111". you can even change your password!
* there is a small procedure you have to do when you have a flat tyre. the TPMS (tyre pressure monitoring system) indicates with a beep and red light that you have a flat tyre and also indicates which tyre is flat. first manually swap the tyre with the spare. then press the mode button on the TPMS twice for 5 seconds. it will beep to acknowledge your request that you have swapped the respective tyres.
* in my 7 seater version, mahindra has pulled back the middle seats a bit behind resulting in more leg space in the middle seats.
* i dint like the fitting of the panel behind the steering wheel. looks like it has been cut with a knife! rest is ok.
* we use premium diesel by indian oil and bharat petroleum. its working fine. engine is smooth and refined.
* the vibration which i mentioned in the gear lever still persists and is only in the 3rd gear. has to get it checked too.
lastly though i am very impressed with my new car, my hand is itching to press the throttle real hard and to exploit the engine's full potential. wish i get the first service done soon. i wanna feel the power of that 120 horses.
5000 kms, 1st service update:
PART DESCRIPTION (QTY.) RATE as follows:
OIL FITER (1) 127.11
GEAR OIL (2) 307.54
DIFFERENTIAL OIL (1) 218.66
ENGINE OIL PREMIUM (6) 840.00
COTTON WASTE (1) 8.88 (ridiculous!!)
W.D. 40 (1) 43.75
TOTAL: Rs. 1545.94
NOT INCLUDED UNDER SERVICE:
MIRACLE TREATMENT (underbody anti-rust treatment) : Rs. 3500
INITIAL HICCUPS FACED:
1. the "whoa" sound coming from the day of delivery itself was finally solved after 3 visits to the workshop! it was traced to the AC motor. on the 1st visit, one of the 2 motors was replaced under warranty. on the 2nd visit, the 2nd motor was replaced. on the 3rd visit, the expansion valve costing Rs. 300 was replaced under warranty. after that, this problem did not re-surface, touch wood!
2. excessive gear lever vibration in 3rd gear not solved. found to be present in all mHAWKs.
3. central locking system by nippon found to be a bit unreliable. a month back, it was working but refused to emit the siren while locking/unlocking. worst is that mahindra dealers do not attend to such complaints. they gave us the number of nippon customer care who will send a person to our place to rectify the complaint. 3 days back, just before the vehicle was to be sent to the service centre, the remote stopped working. but the next morning, it started and is working fine now. i think it must have got wet in the rains, irresponsible driver and poor nippon quality!
4. service by the mahindra service centre (GLOBAL GALLARIE, MUMBAI) is good. the staff behaviour is good. when i called for an appointment for the service, they informed me well in advance about the routine work that will be carried on my vehicle, the parts that will be replaced or checked, what i have to carry with me and the bill amount. vehicle was delivered on time and washed properly including the tyre polish. my beige seats were not spoiled!!!
overall, the vehicle is perfoming fine. the mHAWK engine still suprises me everyday with its amazing power delivery. i am getting an average of 9-10 kmpl in mumbai city. on a recent trip to pune through the expressway, i got an average of 13 kmpl which i think is sufficient since it was doing speeds of 120+ kmph and even the worse pune traffic! felt very stable at speeds of 140-150 kmph with no probems faced. engine was still very refined and the sound was not much of a bother. but above 120 kmph, wind noise exists.
sensors are working fine. cruise control and auto headlights only put to use on express highway. auto wipers is a boon. it works spot on, a superb feature. rear sensors are also good. wish the fog lamps were better though. tyre pressure sensors are good and almost accurate with an error of +0.5 psi.
TOP SPEED TOUCHED: DAY: 30th october, Thursday
Destination: Pune
Route: Mumbai-Pune express highway
this was the brief given to me and i had to reach pune by 8.30 am. so i started off from my house by 5.00 am. it was a chilly morning and traffic was sparse. i reached the expressway in 30 mins flat! normally, it takes an hour! that gave me a thought that i have never gone above 150 or actually tested the top speed of my scorpio, mainly due to traffic conditions. this, i thought, was the perfect oppurtunity. a few kms past the expressway, i set the cruise control at 130 kmph and continued like that till the first toll naka. you can say, i was warming up my car and myself. there onwards, i simply floored the throttle. with the pedal touching the floor, 150 kmph came in no time. then slowly and steadily, the needle rose and finally it touched 170 kmph. after this, i let go as i entered the ghat section! though i know mahindra claims the scorpio has a top speed of 156 kmph, but i must have atleast touched 160 kmph, maybe due to road conditions, i consider an speedo error of 10 kmph.
what i noticed was, even above a speedo indicated 150 kmph, the engine noise was not that audible but what was more pervelant was the wind noise which started at around 140 kmph and increased gradually. also, 1 thing i liked was the SUV felt steady at such speeds, unlike what most say. i left the steering at that speed and the scorpio travelled a straight line without even a slight deviation. yes, i dint try any heroic stunts like sudden lane changes to check its handling! i leave that to professionals!
overall, i was AGAIN impressed with the engine as it was very refined throughout not sounding coarse at all. tyre noise was also under control. but i wish there was a bit less wind noise. mahindra, please look into this!
More reviews will be followed soon!
GEAR OIL (2) 307.54
W.D. 40 (1) 43.75
TOTAL: Rs. 1545.94
Destination: Pune
