One of my car Fiat Avventura has completed 37800 km.
Tyre replacement was on cards.
Earlier tyres, Goodyear EAGLE NCT 5
ideally should have been replaced at 32kkm, but as my father drives very carefully taking care of car & the tyres he managed to push them till now.
Tread pattern
Symmetrical & non directional.
UTQG rating :
Treadwear : 240
Traction : A
Temperature tolerance : A
ECE markings : E13, registered at Luxembourg.
European label : could not find.
Now,
It was 205/55 R16 Michelin PST vs Hankook ventus V12evo vs Goodyear F1 GSD 3 vs Apollo alnac 4G vs Kenda vs Continental CPC2 vs Goodyear TMA.
My requirements were
1) Something better than stock GY NCT 5
in terms of mileage & ,comfort and hardcornering and equally stronger sidewalls.
2) It is me who drive her on long highway trips & my father who drives her in rural areas. So wanted little more comfort & hardcornering safety for me & more comfort for my father.
Michelin PST :
Tread patern: Asymmetrical, (meaning good for hard cornering) & non directional.
Ply composition :
Tread : 2 steel + 2 polyester + 1 polyamide (polyamide gives better ride comfort) I wish, it was with 2 layers of polyamide, making it most resistant tyre against tread bulge/burst )
Sidewalls : 2 Polyester.
UTQG rating :
Treadwear : 340 (best amongst the other tyres in consideration)
Traction : AA.
ECE markings : 'E2'mark present, registered at France under amendment 2 of the ECE regulations. ( no mention of S & W marks) This is probably due to introduction of EU label system by the EU and primacy ST got launched at the same time.
EU label :
fuel economy: C (one of the best amongt the others)
Wet grip.: A(Best amongst the others)
Noise : 69 dB.(one of the best)
Cheapest qoute : 7400 per tyre including fitting alignment balancing.
Goodyear assurance triplmax :
Tread pattern : Symmetrical & Non directional
Ply composition : It is similar to the stock Eagle NCT 5.
UTQG RATING
Treadwear :320
Traction : A
Temperature :A
E label : not found, not sold in Europe.
E marking :[/U]I don't remember.
Best qoute : 6800
Warranty : 3 year unconditional for sidewall bulge /cut, tread bulge burst too.
Barring the treadwear life of 800 units more than the stock tyre & the warranty there wasn't going to be a difference in the ride & handling.
Hankook ventus V12evo :
Tread pattern : Unidirectional & symmetrical (meaning good for wet grip).
Unidirectional tyres are often noisy but the V tread pattern of this tyre is instrupted by groves to make them less noisy.
UTQG rating :
Treadwear wear : 280
Traction :AA
Temperature : A
This tyre was not available with the dealer for inspection of sidewall & tread , since it is slow moving brand in India. they order it and make it available next day.
However, dealer was installing a different size as a upsize on a figo aspire.
I noted :
Ply composition :
Tread : 2 steel + 1 polyester +1 nylon. (1 less polyester as compared to other tyres in my consideration meaning prone for burst /bulge on bad roads)
Side wall : 1 polyester ( only one polyester ply meaning more prone for sidewall bulge or cut) most of other tyres in my consideration had 2 plies of polyester
I needed to see the tyres in my size to confirm above mentioned facts but waiting for a day was not possible. to wait. I speculated that there wouldn't be much difference for my size too.
1 polyester ply of sidewall & lack of a polyester in the tread would not be a good choice on rural roads, also there was not a worldly difference in treadwear life as compared to the stock tyres.
Cheapest qoute : Rs 6800
Goodyear F1 GSD 3 :
Tread pattern : unidirectional(again noisy) & symmetrical.
Ply composition;
Tread : 1 polyester + 2 steel + 1 polyamide ( only one polyester ply makes the tyre prone for bulge or burst, however the polyamide makes the ride comfort better than Hankook ventus V12evo which has nylon instead of polyamide)
Sidewall :2 polyester. (it is better than the Hankook ventus V12evo)
UTQG rating :
Treadwear : 280
Traction : AA
Temperature :A
E markings : found to be registered in EUROPE but don't remember the name of the country.
EU label : not found. Probably because they were discontinued abroad when EU label was made compulsory. However I see most of the uni directional tyres got ' F' ratings for fuel efficiency. (which we were not ready to accept) but they got A rating for the wet grip. Such tyres are more suitable for sport type of drivers.
Not a worldly difference in treadwear life as compared to stock tyres.
Goodyear doesn't offer the 3 year unconditional warranty which they offer for the triple max.
Best qoute : Rs 6700
Continental CPC2 :
Multi brand dealer told me that they are noisy & online reviews were not encouraging.
Ply composition : didn't check.
UTQG rating :
Treadwear 280.
Traction : AA
Temperature :A
EU label :
Fuel efficiency : E (this was unacceptable)
Traction :B( I prefer A rating because there is a difference of 3 to 5 feet in braking distance in between A & B.)
Noise : 72 dB ( moderate but better options were still available)
Hence didn't researched too much.
Best qoute : Rs 8500.
Kenda KR 20 :
Tread pattern : Symmetrical & unidirectional
Ply composition :
Tread : 1 polyester + 2 steel + 1 nylon (only one polyester, hence weak)
Sidewall : 1 polyester (again weak sidewall)
UTQG rating :
Treadwear : 300
Traction : A
Temperature :A
E markings : E4, registered with Netherlands. and has passed the Sound, wet grip tests there.
EU Label:
I couldn't found any, might be because it is not sold there. But other similar tyres in other size got F ratings for FE (Worst) & C rating for wet grip. So felt that there is no reason for them to bring a tyre with better ratings to India for such a price.
Best qoute : Rs 4000
Apollo alnac 4G ;
Tread Patten :
Asymmetrical, non directional.
Ply composition :
Tread : 2 polyester +2 steel +2 nylon ( sturdiest among the others in consideration, but pure nylon gives a bit harsh & little bit uncomfortable ride)
Sidewall : 2 polyester.
UTQG rating :
Treadwear 280
Traction : AA
Temperature : A
E markings : registered with EU (Netherlands)
EU Label :
Fuel efficiency : C (equal to Michelin PST)
Wet grip : B (lesser than Michelin)
Noise : 69 dB.
Best qoute : Rs 6100.
In the end,
I found that single digit variation in the size, speed, load indices, and suffix like EL, RF etc changes the tyre ratings by many units.
Other which were considered but rejected outright because no information regarding tyre quality found on sidewall,they don't bother to mention the ply composition leave aside the UTQG & E markings.
1) Bridgestone B 290
2) Yokohama Adrive R1 (AR01)
Final winner was Michelin PST for my requirements.
Tread pattern
UTQG rating :
Treadwear : 240
Traction : A
Now,
Michelin PST :
Ply composition :
UTQG rating :
Traction : AA.
EU label :
UTQG RATING
Treadwear :320
Traction : A
Temperature :A
Best qoute : 6800
UTQG rating :
Traction :AA
Temperature : A
I noted :
Ply composition :
Goodyear F1 GSD 3 :
Ply composition;
UTQG rating :
Treadwear : 280
Traction : AA
Temperature :A
Continental CPC2 :
UTQG rating :
Treadwear 280.
Traction : AA
Temperature :A
EU label :
Kenda KR 20 :
Ply composition :
UTQG rating :
Treadwear : 300
Traction : A
Temperature :A
EU Label:
Apollo alnac 4G ;
Tread Patten :
Ply composition :
UTQG rating :
Treadwear 280
Traction : AA
Temperature : A
EU Label :
Noise : 69 dB.
In the end,
